  3. question about LSW window in IC5141
  • Views 14971
jimito13
jimito13 over 14 years ago
Dear Community members,
I have noticed that LSW window does not close in IC5141 (currently running sub-version 5.10.41.500.6.143 and assura 4.1)...This problem persists all over the years i am using the tool (including older version apparently) and in order to close it i have to shut down all the cadence suite and restart it!Is there a way that this window closes at last?
Thanks in advance.
Best Regards,
Jimito13
  • Marc Heise
    Marc Heise over 14 years ago
     Hello Jimito13,
     you can minimize it or if you realy want to not see it using SKILL  to hide it with   leUnmapLSW() and bring it back with leRemapLSW()
    Or you start using IC6.1.4 and try the new Layer Assistant which you can close and open as much as you want.
     Kind regards,
    Marc
  • jimito13
    Where do i set this command?Under the dialog box of icfb window?
    Yes,i know the palette that comes with the newer IC,i have used it,but at the moment i am working on a process that is compatible with IC5141 and unfortunately i can't do something about it!
    Thanks for your contribution.
    Best Regards,
    Jimito13
