  3. How to modify pin label property when I create it by sk...
  • Subscribers 133
  • Views 16638
How to modify pin label property when I create it by skill
bobbygang
bobbygang over 14 years ago
Andrew,
  I used schCreatePin command to generate pin in schematic by skill. But I could't modify the font style and height of the pin name. I guess it is attched to a label. So I used schCreateSymbolLabel and schGlueLabel to replace the original one but it doesn't work. A new attchment label was created but the pin had nothing changed.  Is there any command to do this?
Best Regards,
Bobby
    Hi Bobby,
    You should be able to do:
    pinFig=schCreatePin(cv pinMaster "myInp" "input" nil 0:0 "R0")
    pinFig~>children~>height=0.125
    for example.
  • bobbygang
    Andrew,
        It works. Thank you very much. But when  I use other object how can I know how much properties it includes and the name of these property.
    Bobby
    Bobby,
    Well, you can do obj->? or obj->?? To find out a list of attributes or attributes+values for an object. Is that what you mean?
  • bobbygang
    Andrew,
          Yes, that's just what I mean. Thank you!
    Best Regards,
    Bobby
