  3. The way a Param shows up on the symbol.
  • Subscribers 133
  • Views 15730
MarkTown
MarkTown over 14 years ago
I have IC6.15
 I'm creating a new device. There is a VTN parameter that I ned as a boolean.
On the symbol I'd like the Param to show as VTN when its selected or be invisable when its not selected.
The VTN=true or VTN=false seems a bit much text.Plus I have 3 different VTNs.
Can this be done in the in the call back? Will the display value, name or both make this so it can't be done?
thanks for you thoughts
Mark
  • skillUser
    skillUser over 14 years ago
    Hi Mark,
    In the CDF for the VTN parameter you should be able to make the "display condition" a SKILL expression that returns t or nil to control whether the parameter is displayed or not - is this what you are looking for?
    Hope it helps.
    Lawrence.
  • skillUser
    Oh, and in the Interpreted Labels section you can mark the parameter to display only the value, not the name too, does that help?
    Lawrence.
  • MarkTown
     Hi Lawance, thanks for getting back to me.
        I'll have to look into the  Interpreted Labels section, I've not studed that. Its the name of the value I want to turn on and off. The value would be true or false and I'm not interested in displaying that, if possible.
        I was thinking alone the line of your 1st post. The callback and what is exicuted. So something like this:
      ( VTNi
          when((paramID = get(cdfgData 'VTN))
              if(paramID->value && paramID->value != "FALSE" then
              wParamID->display = "name" ; name no value
              else
              wParamID->display = "invisible"  ; no name and no value
    but that many not be able to over ride the
    cdfId->paramLabelSet = " ... VTN ... "  in the CDF.
    That's the concept ... I've not yet tried to figure outthe exact code. That's what I'm starting to look into now.
  • MarkTown
    n/a
