  3. assura lvs with SYNTAX ERROR
  • Subscribers 133
  • Views 15445
lindawilliam
lindawilliam over 14 years ago
I am getting this assura LVS error
detial in the attach file
I would appreciate any helpful answer.Thanks in advance.
    Not enough info provided, I'm afraid. The syntax error is pretty much useless without knowing what it is complaining about. Try logging a service request with customer support where maybe it is easier for you to supply all the necessary information such that it is not in a public forum?
  • kamit
    kamit over 14 years ago
    Andrew is right, you should file a Service Request to Support!
    BTW, the syntax error shown seems to be unrelated to Assura, as the log file in snap-shot shows a normal termination for Assura with some compare errors. That mean Assura run has completed and user need to debug the compare errors.
    Another thing that I noted is, you are using an unsupported version of Assura. Support folks may not be able to help you unless you upgrade to the most latest version of Assura which is Assura41. (You can get the latest hotfix from downloads website.)
    Cheers,
    -kamit
