  3. layoutXL Gen from source doesn't give correct sizes.
  • Replies 13
  • Subscribers 133
  • Views 8026
MarkTown
MarkTown over 14 years ago
 If I place my Pcell by hand the cell works fine. Sizes are what I expect them to be.
Gen from source gives me small values that can't be laid out.
The symbol though has "90n M" which doesn't match other tech files I've worked with "90n"
 I've tried two different ways of doing the CDF:
    cdfCreateParam( cdfId
        ?name           "w"
        ?prompt         "width"
        ?defValue       "0.2n"
        ?parseAsNumber  "yes"
        ?type           "string"
        ?units          "lengthMetric"
I've also tried the following default value:
minMosWidth = 0.2 * 1e-6
?defValue       sprintf(nil "%g" minMosWidth)
Neither gives me the desired result.  Any thoughts?
Mark
    Mark,
    Without seeing your pcell, who knows what the problem is. Most likely there is a difference between what the pcell is expecting and what the CDF value is - either in the type of the value it sees, or in the value. Maybe the pcell is expecting the value to be in microns?
    Above you seem to be setting the default value in the first case to 0.2 nm (which is a bit small and rather ahead of state of the art technology).
  • MarkTown
     Your right Andrew, I should have .2u not .2n.
    That didn't solve all the problem with the size tho.
     The Pcell code is:
       ;  Define formal parameter name-value pairs.
          ( w     0.2 )
          ( l     0.09 )
         width = w
         length = l
    So I don't change the value in the Pcell. If I multiply w by 1*e-6 then virtuoso locks up when I load it.  Kinda strange.
    Any more thoughts?
    Mark
    Mark,
    The type of the pcell parameters is float, but the type in the CDF is string - so you have a mismatch. They need to be consistent, and ideally the default values should be consistent. In this case you have the w in the pcell in microns, but the CDF in metres. Consistency is the key.
    You could define the default values in the pcell as also being strings, and then use something cdfParseFloatString() in the pcell code to convert to a number, and do whatever scaling you need.
  • MarkTown
       Thanks for the help. I got all the params to be consistent and then the sizing in the Pcell to work.
    Mark
  • MarkTown
     Well, turns out there is still an issue with the size of the Pcell.
    If I places the nsoi Pcell thru layoutXL gen from source I get the correct size transitors.
    If I instanciate the pcell from my layout cell I get very large transistors. This makes sence in the way I've changed the Pcell code to get it to work with the gen from source.
          ( w     "0.2" )
          ( l     "0.09" )
    these lines work with gen from source.
           width  = cdfParseFloatString(w)* 1e6
           length = cdfParseFloatString(l)* 1e6
    These lines work when pcell is instanciated.
    ;       width  = cdfParseFloatString(w)
    ;       length = cdfParseFloatString(l)
    I currently don't have any call back called.
     There is the CDF code:
        ;;; Parameters
            ?name           "w"
            ?prompt         "width"
            ?defValue       "0.2"
            ?type           "string"
    ;        ?callback    "nsoiCB('w)"
            ?name           "l"
            ?prompt         "length"
            ?defValue       "0.09"
            ?type           "string"
    ;        ?callback    "nsoiCB('l)"
    Anyone got any thoughts about where the conversion should take place from schematic to layout?
     Mark,
    My guess is that your schematic has the components instantiated with values such as "0.2u" - and so with the scaling lines in the pcell, it correctly transforms it into layout units (microns).
    When you're instantiating in the layout directly, and picking the value as the default (0.2), then that scaling would result in a transistor width of 20cm - which is a tad large.
    So it's a units mismatch problem - you need to decide what values you want the user to enter, and then be consistent about it. Maybe your pcell default and CDF default should be "0.2u" and then you will need the scaling in the pcell to convert into microns since the layout will  be drawn in microns.
    A bit of a guess because obviously I can't see everything...
  • MarkTown
     Yes, Andrew, I'm aware that its a units issue. I've tried quite a few different units trying to get them to match. I get the code working one way and then it breaks another way.
    For something as easy to mess up as this, it would be nice if CD not only had an example like the 90nm sample code but also an explanation of why each cb, cdf, il and symbol has to be what it is and why. Where the conversion should be etc. I've thought I had ever line matched up with the CDS examples and yet it still didn't work.
    So now its just going to ahve to be skill code that is placed. Its easy to make that work.  No gen from source in this version.
    thanks for you help
    Mark
    Mark,
    There is ABSOLUTELY NO REASON why you should not be able to make it work for both scenarios. Once you've decided whether the user will be setting the dimensions  in metres or microns on the component, you can make it consistent everywhere.It would be very odd if you specified the dimensions differently when placing an instance on the schematic from placing an instance on the layout.
    This is not complicated - so I'm slightly mystified as to why it is seen as being complicated.
  • MarkTown
     Yup, I know there isn't a reason. But I've not been able to do it in 2 weeks of trying.
    I've never been this flustrated trying to program in CDS.
  • skillUser
    skillUser over 14 years ago
    Hi Mark,
    Would you like to create a Service Request to get support directly from a Cadence engineer?  This would likely give you better support than the online forum, especially if you have reached a point of frustration...
    Lawrence.
