  3. How to set AWD curves default property?
  • Subscribers 133
  • Views 15004
SUEE
SUEE over 14 years ago
The default colors of my AWD curves are some dashed lines and flashing.
Where/how could I set the default AWD curve properties?
Thank you !!
     The colours used are defined by the y0-y9 drawing layers in the technology file, and hence whatever they have been mapped to in the display.drf file. Some PDKs change these to be dashed lines etc - so you'll need to change the packet definitions in the display.drf to something better. The Display Resource Editor can be used for this (in the Tools menu in the CIW).
  • SUEE
     Great, it is done.
    Thank you so much !!
