  3. spectre - 7031 error: SST2: Input/output error
  • Subscribers 133
  • Views 2445
pratikdd
pratikdd over 14 years ago
I am doing a transient analysis for around 100us to check for a PLL Design and after 640ns im getting an error message:
Error found by spectre at time = 639.8ns during transient analysis 'tran'
ERROR (SPECTRE-7031) : SST@ Error: Input/output error.
Can someone please help me put regarding the same.
thanks in advance.
  • Screenshot--home-da-daha5520-simulation-pll_trial-spectre-schematic-psf-spectre.out.png
    It might be that the disk filled up, or it might be a bug in the SST2 output from the simulator. Assuming you're using a recent MMSIM version, I'd suggest reporting it to customer support at http://support.cadence.com but you can probably  workaround it by setting the output format to psfbin or psfxl on Save->Options (near the bottom of the form). If that's not there, use:
    envSetVal("spectre.outputs" "simOutputFormat" 'string "psfbin")
    In the CIW before starting ADE (can go in the .cdsinit too)
  • pratikdd
    Thank you so much for the instant reply. Yes, indeed it was due to disk space. I deleted all the .psf files which gave me lots of free space. thanks for your reply
