  3. Altering model parameter of single instance
  • Subscribers 133
  • Views 17172
ChrisEAS
ChrisEAS over 14 years ago
Hi there. I'd like to convince Spectre to alter a model parameter of a single instance only. Say I'm having...
 M0 (d g 0 0) mymodel l=1 w=1
 M1 (d g 0 0) mymodel l=1 w=1
and I'd like to have something like
 alter1 alter dev=M1 param=tox value=3.141
However, the above statement won't work. I'd really like to avoid defining a new model each time...
Thanks!
    I don't think you can - it would have to disable model sharing in this situation. You'll need to contact customer support an request an enhancement (unless I'm mistaken and it can be done somehow). For example, you can't do dev=M1 mod=mymodel - dev and mod are mutually exclusive.
  • ChrisEAS
    Since I wanted to work with several alters, this is quite a shame. I was then trying to create model aliases, eg.
     model tox_model mymodel tox=3.141
    but that didn't work either. Might be due to my Spectre version 6.1.1. So my only option seems to be a separate model card for each altered parameter, or is there another possiblity?
    Chris
    That's quite an old version of spectre - probably 5-6 years old - newer versions do support model aliases (although not sure if you can modify the parameters still - I'll leave that as an experiment for  you),
  • ChrisEAS
    Is it possible to have a model alias for a model from a model group? Suppose there this group model_group. Writin
      model tox_model model_group tox=3.141
    I get the cryptic error message "It is illegal for model tox_model which based on model group model_group". Next I tried to pick a model from the group by writing
      model tox_model model_group.1 tox=3.141
    which didn't work either. Is there a way to achieve this?
     Chris
    Chris,
    Not as far as I know. I'd suggest contact Customer Support.
