  3. [SOLVED] Shape magnification in OA
  • Views 15050
MayskiyJukFSL
MayskiyJukFSL over 14 years ago
Hi!
As I understand magnification function is now not supported in Layout suite. Is there any other way to magnify shapes in OA? May be some workaround?
Thanks in advance.
Solution: You need to transform shapes into Pcell and then place them with reqired mag.
  • Quek
    Quek over 14 years ago
    Hi MayskiyJuk
    You can try dbCreateXformPCell as described in solution 11552600. A layout can also be magnified using "XScale" cmd in a terminal window.
    Best regards
    Quek
