  3. Overlay plots with ocnYvsYplot
  • Subscribers 133
  • Views 15270
shankarp
shankarp over 14 years ago
I use the command "ocnYvsYplot()" to plot a waveform against another in Ocean. But I am not able to overlay two or more plots on a single graph. The second graph always goes to a new subwindow. Is there anyway to plot more curves on a single graph.
Shankar
    Shankar,
    Which version (and subversion) are you using? I just tried using IC615 ISR7 (6.1.5.500.7) and this worked OK - so maybe you'll need to give more details as to what you're doing if you're using a similar version.
  • shankarp
     Hi Andrew
    The version of cadence we have is 5.10.41_USR3.27.30
    I can't upgrade to any later version. But I found a work around by creating a waveform object using your script abChangeXAxis.il. I generated my desired waveforms and plotted using the regular plot command and that worked.
    Shankar
