  3. How to add multiple variables to ADE modelFile?
  • Subscribers 133
  • Views 15451
adeuser777
adeuser777 over 14 years ago
Hi, I am trying to load default model files in ADE which are defined as variables. I have a scenario like below. A = "/tmp/A.scs" B = "/tmp/B.scs" If I execute the below .cdsinit variable, it doesnt work. It's expecting all the model files in a signal double quotes. envSetVal("spectre.envOpts" "modelFIles" 'string A B) // Doesn't work. envSetVal("spectre.envOpts" "modelFIles" 'string A) // This works envSetVal("spectre.envOpts" "modelFIles" 'string "/tmp/A.scs /tmp/B.scs") // This works. But I have a dependency on these variables. And I need to use them. I need to implement something like this, but with the use of variables. envSetVal("spectre.envOpts" "modelFIles" 'string "/tmp/A.scs #;/tmp/B.scs") Any ideas? Thanks, Ram
    How about envSetVal("spectre.envOpts" "modelFiles" 'string strcat(A " " B)) ?
    Your second example has the second file ignored (because of the #) - if you needed that, the strcat could be used to build the resulting string.
  • adeuser777
    Thanks Andrew. I could get it working with your suggestion. -Ram
