  3. In ADE waveform window, how can curves be ploted in different...
  • Subscribers 133
  • Views 18381
In ADE waveform window, how can curves be ploted in different subwindows automatically?
SUEE
SUEE over 14 years ago
My question is:
I want plot many, say 15, curves automatically right after the Spectre simulation is finished, but have no idea how to separate them automatically into different subwindows. For inctance, 3 in the 1st subwindows, 5 in the 2nd subwindows, and 7 in the 3rd subwindows.
Every time I need to add subwindows and drag every curves into the corresponding subwindows; it takes time and looks stupid.
How can these curves be plotted in separate sunwindows automatically?
Thank you very much !!
  • SUEE
    I found in "ADE/Session/Save State" I could check the "Waveform Setup" & "Results Display Setup", but it does work to really save the the latest plot settings. Every time I re-run the simulation all the curves get together in one winodw again.
    Please help !!
    In IC615 you can use the "Refresh" mode of ADE (rather than "Auto" mode) to re-plot the results using the last graph setup, whereever possible.
    Before that, you're a little limited in your options, I'm afraid. You may be able to turn off auto-plotting, and then do a Refresh or Reload operation in the graph window (depends on which version you're using - you didn't say. Note the Forum Guidelines suggest you provide this information to allow responses to be tailored to the version you're actually using).
  • SUEE
    Sorry, I forgot to mention the version I am using: 5.10.41.500.5.105
    So the ADE/Session/SaveState does not help, right?
    How about the WaveForm/Window/Save option? What can it do?
    Thanks a lot !!
