  3. Design Variables in ADE sent to a Plot Window
  • Subscribers 133
  • Views 15857
r7aaex
r7aaex over 14 years ago
Hello, I am sure there is an easier way than what I usually do... that is, I usually hand type my conditions on the plots I generate.  The conditions are my design variables.  Do you know of an easier way to do this (in ICFB 5141 or OA) where the conditions are passed in a more automatic way to your plot.
 Thanks a bunch for any tips.  Best regards,
Jorge Vega
    Jorge,
    How about Results->Printing/Plotting Options, then turn on "Design Variables" in the Annotations section? That should do what you want.
  • r7aaex
    Thanks a bunch for this tip.  This does the trick.
    I noticed that you cannot make edits to the text sent to the plot.  Do you know if this is always the case?
    Thanks again for your help,
    jva
  • r7aaex
    By double clicking I get an attributes window and the text can be modified there.
    Thanks again!
