  3. How to adjust the AWD/Curves window?
  • Subscribers 133
  • Views 1060
SUEE
SUEE over 14 years ago
I am using IC 5.10.41.500.5.105
Every time when I use AWD to plot many curves in the same waveform window and want to check/edit the curves, I find it difficult to use the "Curves" window because the size of its inner menu where I could select the curves is fixed, no matter how I adjust the outter "Curves" window size.
I am wondring where I could set the inner menu size, if possible.
Thank you !!
    Assuming it's the Curves->Edit form you're talking about, the answer is no. This is also obsolete (since AWD is no more in later versions) and so it's not going to get fixed to be resizable.
