  3. CADENCE: SKILL function for get the marker from RVE into...
  • Subscribers 133
  • Views 16378
CADENCE: SKILL function for get the marker from RVE into a layout cellview
simonec
simonec over 14 years ago
Are there any skill functions for get the co-ordinates of the bbox highlighted from the RVE related to a DRC report into a layout cellview?
The highlight from the RVE are not drawed into the layout so I can't recognize them using for example cv~>shapes (where "cv" is the cvId of the cell).
Simone
     Simone,
    This is a question best asked of Mentor Graphic's support, since the Calibre interface is theirs. I suspect they probably use "hilight sets" to do this, using geCreateHilightSet(). However, even if you knew the name of the variable containing the hilight set, you can find the hilight objects, but you may not be able to find the details of the coordinates as these aren't necessarily exposed in SKILL. Potentially geAddHilightFig would allow you to find the associated shape, but I doubt that's the case because the interface probably doesn't know the source object to highlight - and for many rules it would be gaps between shapes, or derived layers that need highlighting.
  • simonec
     Thank you Andrew!
    I'll try to contact Mentor
    Simone
