  3. cadence IC 6.14 license issue
  • Replies 7
  • Subscribers 136
  • Views 27359
FedericoPI
FedericoPI over 14 years ago
hi all, I am new to this forum.
I have properly installed Cadence IC 6.14 but I can't figure out how to set the license to work properly.
The license server is on a remote machine, and i have no license.dat files.
I think i should only set CDS_LIC_FILE to 5280@servername, but it doesn't work at all.
Which is the right procedure? Should i do something different?
I copied .cshrc, .cdsinit and .cdsenv to my home directory and edited with my path and with CDS_LIC_FILE, CDS_AUTO_64BIT, CDS_LIC_ONLY variables.
Thank you!
    Exactly what you need to set CDS_LIC_FILE to would depend on the port that was used on your license server, and also the hostname.
    Can you try doing:
    lmstat -a -c 5280@licserverhostname
    and see if that's returning anything? If it is, you can set $CDS_LIC_FILE to the same thing:
    setenv CDS_LIC_FILE 5280@licserverhostname
    or if using bash/ksh rather than csh, it would be:
    export CDS_LIC_FILE=5280@licserverhostname
    If lmstat doesn't return anything, you'll need to log onto the license server and check that the license daemon is actually running, and so on.
  • FedericoPI
    i've tried: lmstat -a -c 5280@licserverhostname
    dedalo> lmstat -a -c 5280@xxx.xxx.xxx.xx
    lmstat - Copyright (c) 1989-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
    Flexible License Manager status on Mon 12/5/2011 17:55
    License server status: 5280@giove
    License file(s) on giove: 5280@giove.iet.unipi.it:
    lmgrd is not running: License server machine is down or not responding. (-96,7:2 "No such file or directory")
    dedalo>
    the server name and port are right. i-ve checked. I've run the same command on an old machine, and it shows a correct output.
    I figure out that there is some problem with my communication with the server. Am i right?
    In this case I will contact the license server admin.
    Maybe there's a port blocked, or a firewall in the way.
  • FedericoPI
    thank you very much, i solved. My admin had to insert me in a list on the license server.
    just to tell you, maybe it can be useful, if i do lmstat -c ...@... it doesn-t work, however the license can be found.
    Another important question: i get the error when starting Library Manager:
    cdsServIpc: ipcISAliveProcess connection timeout
    and so on.
    I found this:
    /forums/p/12685/18368.aspx
    It seems i have to add this string in my /etc/hosts file
    127.0.0.1               <machine_name> localhost.localdomain localhost
    i only have to do this to solve?</machine_name>
    It's quite possible that the problem will be fixed by that (you may not need the localhost.localdomain bit - I only have localhost in mine). Did you try it?
  • FedericoPI
    solved!
    last question: i installed DFII package hotfix 6.1.4 and so on
    i realized Spectre and other simulators are not there. Which version of MMSIM should i get? MMSIM 7.2 right?
    MMSIM 11.1 is the latest version (the versions went 7.1, 7.2, 10.1, 11.1 - a jump between 7.2 and 10.1 to move to the year number scheme).
    So unless you have a good reason to do otherwise, I'd use MMSIM11.1 . Be aware that MMSIM 11.1 has a minimum supported OS release of RHEL5.0 though.
