  3. Table generated in the calculator
  • Subscribers 133
  • Views 17239
Cooktime
Cooktime over 14 years ago
Hi, All, I have a question about the table generation from calculator of Virtuoso 6.1.5 version. I did an AC analysis in the cadence simulator, and put the wave in the calculator. I'm trying to generate a table to display the data by clicking the button "table" in the calculator. There used to be a popup window after clicking the button to choose the start/end as well as the step/scale stuffs in old Virtuoso version, while in 6.1.5 version, the table automatically shows without asking anything. Is there any one knows how to set the step and scale in .1.5 version? Thank you in advance.
  • Ashish Patni
    Ashish Patni over 14 years ago
    Hi Cooktime,
    The display of table is somewhat different in IC6.1.5 ViVA which is Qt based. The way you can do that is once the table is displayed, you can go to any cell on the X-axis column data and do a RMB and then select 'Sample Values'. This will Pop up the range and step dialog box which can then be filled as per your requirement.
    Ashish
  • Ashish Patni
    I forgot to mention one thing that this is available from IC615 ISR6 onwards. You may have to upgrade to the latest IC615 ISR in order to use this. Prior to this ISR you can go to Expressions -> Display Options.. menu item in the Table Window (Results Display Window) and then use Size, From, To settings as step and range modifiers.
    Ashish
  • Cooktime
    I got it. Thanks a lot!
