  3. Error Tolerance Settings...
  • Subscribers 133
  • Views 16497
Muffassir
Muffassir over 14 years ago
 Hi all,
Greetings!!!
How can i know what are the error tolerance settings in my simulator.How can i check it?(PLease show me the path). I am using Cadence 6.1.4.500 and virtuoso,ADE L/XL and gpdk180/90/45.
Can i change them.Do they play any role when i am simulating the circuits at very low currents for subthreshold operations of Low Power circuits.If yes then how?
Thanks in advance!!
    Your problems are unlikely to be anything to do with simulator tolerances, but these can be set with various options on the analysis itself (e.g. the options form for the dc analysis), or on simulation->Options->Analog (settings such as reltol - maybe iabstol if the currents are very small). However, even if accuracy settings were important, it's unlikely you'd see constant currents where you were expecting them to vary - almost certainly that's a circuit/testbench problem (as I suggested in my reply to one of your other posts).
    You should read the spectre user guide (use cdnshelp from the MMSIM installation to read this, or look in <MMSIMinstDir>/doc/spectreuser/spectreuser.pdf or get a copy of the Designer's Guide to SPICE and Spectre
