  3. Cadence environment variable
  • Subscribers 133
  • Views 18829
slim5
slim5 over 14 years ago
Does anybody know which environment set the value of rabsshort used in DC and transient simulation? The simulator engine is spectre. Thanks
S Lim
    I don't believe there's a specific field on the form for this, so you'd have to go to Simulator->Options->Analog and then on the Miscellaneous tab in the Additional Parameters field enter rabsshort=XXX (whatever you want).
    If you're asking for a cdsenv setting for the same field, you can use:
    spectre.opts additionalArgs string "rabsshort=XXX"
  • slim5
     Thank you Andrew for the prompt reply. I am just wondering, what does the parameter rabsshort represent?
    S Lim
    That's a bit odd - you're asking how to set it, but don't know what it's for! So why do you want to set it?
    From the UNIX command line, "spectre -h options" will tell you about this option (and others).
  • sunilm
    sunilm over 14 years ago
    You may also look into the  solution # 11588420  to get more details on rabsshort parameter .
    Sunil
