  3. spectre, user defined unction, use probe as argument
  • Subscribers 133
  • Views 15379
demsar
demsar over 14 years ago
Hi!
I would like to use user-defined functions, e.g.
real mySum(real a, real b){return a+b;}
I am able to use this function, if using real  values, but if I use probes, e.g.
save  v(idout\<1\>)
simulator lang=spice
.param sumOfSig ='mySum(v(idout\<1\>),v(idout<0>))'
.probe tran
then save works (signal is there), but the function evaluation fails with:
Error found by spectre during transient analysis.. during task MDLControl.
ERROR: Unknown parameter name idout<0> found in expressino
Any idea?
Thanks and bes regards
Blaz
    Blaz,
    I don't think this is possible, since you can't have a parameter which is a function of a measured voltage. You can use the bsource component to do this kind of voltage dependency, so maybe that's what  you want?
    Perhaps you should log a service request with Customer Support to cover this in more detail.
