  3. I can't define my function in calculator
  • Subscribers 132
  • Views 1634
TiNat
TiNat over 14 years ago
Hello. I've read manuals about calculator- part "Defining Functions and Function Keys" but I can't implement it. I want to calculate threshold voltage of nmos. I wrote such function: vto=(ymax(deriv(IS("/M0/D")))*cross(deriv(IS("/M0/D")) ymax(deriv(IS("/M0/D"))) 1 "either" nil nil )-value(IS("/M0/D") cross(deriv(IS("/M0/D")) ymax(deriv(IS("/M0/D"))) 1 "either" nil nil ) ))/ymax(deriv(IS("/M0/D"))) where IS("/M0/D") is stack expression. I don't understand where I must write this expression. I need use only stack, no additional arguments. I don't find such problem in google in other forums. Help me please, how to organize such user function in calculator. Thank you for your answers.
    Try this. I reorganised the code a little (you should check this, because I didn't really have anything to check it). As you can see, I broke down the code to make the calculations simpler. You need to load this code (put it in a file and use load("filename.il") in the CIW or in your .cdsinit file), and then call MYthreshVoltageReg() to register it. There are quite a lot of solutions on Cadence Online Support for defining calculator functions. Note that in IC615 you also have the "Expression Editor" which allows you to define dependent expressions which would be an alternative to writing this code - but it depends on how often you're likely to use it, I guess.
    procedure(MYthreshVoltage(current)
    let((di diMax xMax vto)
      di=deriv(current)
      diMax=ymax(di)
      ; this can probably be done with xMax=xmax(di)
      ;xMax=cross(di diMax 1 "either" nil nil)
      xMax=xmax(di)
      ; last value in function is return value
      vto=(ymax(di)*xMax-value(di xMax))/diMax
    procedure(MYthreshVoltageCB()
      calSpecialFunctionInput('MYthreshVoltage nil)
    procedure(MYthreshVoltageReg()
      calRegisterSpecialFunction(list("MYthreshVoltage" 'MYthreshVoltageCB))
    ; call MYthreshVoltageReg() to register the function as a User Defined SKILL
    ; Function in the calculator
