  3. Measurement of Duty Cycle Distortion (DCD) using OCEAN
  • Subscribers 133
  • Views 17101
LeJonT
LeJonT over 14 years ago
Is there any suggestive method for measuring Duty Cycle Distortion (DCD) by Cadence?
I could see different suggestions over the Internet on this; for example, feeding the design with a clock-pulse and finding the difference between time periods of clock cycles. What would Cadence suggest?
Since this is a generic question, not sure what other information is required to be posted here. Any help would be appreciated. Though I'm looking for help with OCEAN, suggestions on Measurement methodology for DCD itself might help to get it done.
    IC61X versions have a function period_jitter which will capture the variation in one period to the next, but not the variation in duty cycle. To do that you'd probably need to write something which actually tracked the positive and negative threshold crossings and computed the variation yourself (i.e. a bit of SKILL). Exactly what you would do rather depends on precisely what you're trying to measure.
    Sounds as if it is something that could be generally useful though, so you might want to contact customer support to add this as an enhancement to the calculator functions.
  • LeJonT
    Thanks Andrew!
    While working on this, I've raised a request for the enhancement as well (Service Request #42762532).
    Regards, Leo
