  3. Integrated noise for opamp is not converged.
  • Replies 10
  • Subscribers 133
  • Views 19986
Jacki
Jacki over 14 years ago
I am simulating a traditional two-stage operational amplifier with miller and lead compensation. The DC gain is 70dB, and gain bandwidth is 580MHz, with the phase margin 115 deg.
After I achieve the specifications above, I start to simulate the integrated noise. The opamp is fully differential, the load is pure capacitor in each branch with the value 350fF. According to the first-order filter theory, the final integrated noise should be KT/C. For each branch, the integrated noise is 1.08e-4 volt.
When I use ADE L/print/noise summary to plot the integrated noise, the results are as follows,
When integrated band is from 1KHz to 10MHz,
total summarized noise = 0.132026V, total input referred noise = 6.20415e-5V.
When integrated band is from 1KHz to 100MHz,
total summarized noise = 0.132042V, total input referred noise = 1.10047e-4V. According to the simulation results, it seems the total summarized noise is converged, and the input referred noise is increasing when the band is higher (not converged).
When I show this results to my boss, he told me how the total summarized noise can be so large, it is around 132mV!!! For the opamp, the noise cannot be so high. Compared with the value of KT/C, it seems the integrated noise is huge.
    1. My first question, why the integrated noise of the opamp is so large. How does spectre calculate the input referred noise?
According to Ken's view from designer guide "the input-referred noise is the ratio of the output noise to the gain". When the integrated band is larger, the gain of the opamp is dropping, maybe it is the reason why the input referred noise becomes worse as integrated band is higher. But my boss told me when the band is larger, the gain of the opamp is dropping, the noise of the opamp at higher frequency is dropping as well, therefore the input referred noise should be converged too even for the infinite integrated band.
    2. My second question is how to get the converged integrated input referred noise if the integrated band is going to infinite. How Cadence Spectre calculate the input referred noise in ADE L->results->print->noise summary?
    I am confused now. Anybody can tell me give me some help. Thanks!
    Spectre (as do all circuit simulators) compute the total output noise - that's the primary output. They do this by adding a number of noise sources around each device, where the magnitude of the noise at the source is dependent upon the size/value of the device and the operating point (depending on the type of noise). It also computes the transfer function from this noise source to the output of the circuit. It multiplies the noise at the source by this transfer function, and then sums up the total noise power at the output of the circuit. This can then be represented in either V^2/Hz or V/sqrt(Hz). If you plot the waveform representing the noise at the output, you'll get one of these - noise versus frequency. You can then integrated it over a band, e.g. using the rmsNoise function in the calculator, or using the noise summary form - it does a straightforward integration to give the noise in a certain bandwidth.
    Input referred noise is computed by simply dividing the total output noise by the transfer function from the designated input source to the output. If there's more gain, there's less input referred noise (at a particular frequency) and vice versa. So whether it "converges" is dependent upon the bandwidth of the circuit. Note that input referred noise is not terribly meaningful - it's only useful with knowledge of the transfer function of the circuit - and is just a way of representing the output noise in a different (and sometimes more convenient) manner to aid hand calculations and noise budgeting in your design.
    Now, I can't comment on your circuit (without having seen it), but the first step would be to look at the noise summary in ADE (Results->Print->Noise Summary) which allows you to filter the devices and identify which are causing the biggest noise contribution. It's very unlikely that it is wrong unless you have some fundamental modelling error or the devices are not the size you thought they were. Note that all the noise contributors are in terms of the output referred noise they produce - so you can compare their impact.
  • Jacki
    Hello Andrew,
         Thank you very much for explaining how Spectre calculates the noise. I am clear now.
         I think maybe I can use the total integrated output noise to be divided by DC gain of the opamp to calculate the input referred noise by my self. If I remember correctly, in designer guide, there is a post about the calculation of input referred noise, it is
    total integrated output noise \ DC gain.
        Am I right?
        Thank you.
        Jacki.
  • Jacki
    By the way, my target to calculate the input referred noise is to calculate the accuracy of swithced-capacitor amplifier.
    Jacki,
    No, it would not be divided by the DC gain. The noise at each frequency should be divided by the gain at that frequency (which is what spectre does). Dividing by the DC gain is not going to be terribly meaningful if there is any kind of gain variation within the noise bandwidth.
    If you're simulating a switch capacitor circuit, you should use PSS and PNOISE (there's a paper on this on the Designer's Guide too), because otherwise you're only finding the noise transfer function at a single bias point, rather than giving you the time-averaged noise over the clock period.
  • Jacki
    Hello Andrew,
         Thank you very much to correct my misunderstanding.
         I will do PSS and PNoise in SpectreRF.
         Best Regards!
         Jacki
    Jacki,
    Note that if the part of the circuit you're analysing is continuous time, then you wouldn't need to use the periodic analyses, but if it's switch cap, then almost certainly you would.
    Good luck!
  • Jacki
    Hello Andrew,
        Can I ask a question not related Cadence Spectre usage?
        For the switched-capacitor amplifier, if I want to realize the accuracy is 10 bits, and I assume only the noise influences the accuracy, other mismatches, distortions are ignored. The amplification of the SC-amplifier is 2 (magnitude) with the input peak to peak signal 100mV, and therefore the output signal peak to peak is 200mV.
        Now if I want to realize the 10-bit accuracy, I think I have to calculate the integrated noise, then referred to the input. Am I right? Actually I am confused about calculate the accuracy of SC-amplifier. Can you give me some comments, hints?
        Thank you!
        Jacki
    Hi Jacki,
    Not sure why that would imply you have to do the noise calculation referred to the input. Presumably you could calculate the magnitude of an LSB at the output of the circuit (if you're telling me that a full scale output is 200mV pk-pk then an LSB would be roughly 2mV pk-pk. It's whether the noise at the output is large enough to mask the output signal. Input referring it doesn't particularly tell you any more; after all, the noise is really appearing at the output, so a comparison there would seem sensible to me.
    Anyway, there are almost certainly better places to find this information (it's been a while since I designed switch capacitor and DAC/ADCs, so I'm a little rusty!) - numerous books, or the design forums on the Designer's Guide
    Best Regards,
  • Jacki
    Hello Andrew,
         Thank you very much for your help. I will check the output. The reason I am checking the input referred noise is my boss tell me for the SC-amplifier, the input sampling noise is around KT/C, so I want to add the amplifier's noise together, then I can estimate the accuracy of SC-amplifier.
        Best Regards!
        Jacki
  • samiic
    samiic over 14 years ago
    Hi jacki,
    its enough to consider the noise at the output (over the band that you're interested in). Anything at the input of the amp will be amplified by the gain and therefore referring the noise back to the input doesnt really help you. (m*A)/(n*A) and m/n have the same result after all.
