  3. pipo command not found
  • Subscribers 132
  • Views 15086
bharatesh
bharatesh over 14 years ago
 When i open cadence virtuso,for layout design,its showing error that pipo problem and pipo command not found.......can anybody help how to get out from this problem....pleasegive a solution to this mail id..........bharatesh7@gmail.com
    You broke the Forum Guidelines by not only appending to an old thread, but picking one that had absolutely nothing to do with your problem. That's a very good way of increasing the likelihood of your post being ignored. I split it into a separate thread and retitled it.
    You also didn't say which version you're using. My wild guess is that you're running an IC61X release but have some menus files for IC5141 in your setup so that it's trying to include the IC5141 menus. Do a "cdswhich -all menus" in your working directory when you start and see if there are any, and move them aside, and see if that fixes your problem.
    Otherwise you'll need to give more details (which would have been wise in the first place).
