  3. Verilog-A read file separated by delays
  • Replies 12
  • Views 26216
kennethbrun
kennethbrun over 14 years ago
I want to create a Verilog-A module (intended for Spectre simulations) that will read a stimuli file on some predefined format and apply the stimulis to the outputs.
The input stimuli file format could be like this:
OUT1=1
OUT2=0
# = 25
OUT1=0
OUT2=0
In the above file, the intention is to initially set OUT1/2 to some well-defined value and then change them 25 time units (ps in this case) later. I create the file myself (in another tool) and the format is not fixed in any sense, but the basic concept is, that it should include both timing and signal/value information.
 I've been trying to create this Verilog-A module, but I got stuck while trying to create the time delay. Below is my Verilog-A code so far. After some initial setup, the idea is that I run a check at each time unit step (~1ps). If a delay counter is higher than 0, then I count it down, if not: then I read the file (and potentially changes the delay counter when "#=250" is read).
When simulated 500ps in Spectre,  the last to output assignments are never effectuated. According to my debugging, it seems that the file pointer has reached EOF when exiting the inner loop. But I do not understand this, and I cannot see any alternative implementation to avoid this problem - any suggestions for a way through this?
 module vloga_component(vdd1v2,out1, out2);
   output out1;
   electrical out1;
   output out2;
   electrical out2;
   input  vdd1v2;
   electrical vdd1v2;
   parameter string fileString = "/tmp/default" ;
   integer   fd;
   integer   testint1,testint2;
   integer   out1var,out2var;
   string signalName;
   integer   signalVal;
   integer   delayCounter;
   analog
     begin
    // THIS BLOCK IS FOR FILE READING:
    @(initial_step)
      begin
         delayCounter = 0;
         fd = $fopen(fileString, "r");
      end // @ (initial_step)
    @(timer(0,1e-12))
      begin
         if(delayCounter>0)
           begin
          // PART OF LOOP WHERE THE DELAY IS IMPLEMENTED
          delayCounter = delayCounter-1;
          $display("Remaining delay: %d ps", delayCounter);
           end
         else
           begin
          // PART OF LOOP WHERE THE FILE IS READ
          while (delayCounter==0 && (!$feof(fd)))
            begin
                    testint1 = $fscanf(fd, "%s=%d", signalName, signalVal);
               case(signalName)
             begin
                $display("WE GOT A MATCH: %s = %d ; TEST2=%d",signalName,signalVal,testint1);
                $display("Delay: %d ps", signalVal);
                delayCounter=signalVal;
             end
             "OUT1" :
               begin
                  out1var = signalVal;
               end
             "OUT2" :
               begin
                  out2var = signalVal;
               end
             default $strobe("Error. Too weird: %s", signalName);
               endcase // case(signalName)
            end
           end // else: !if(delayCounter>0)
      end
    V(out1) <+ transition(out1var,0,1e-12);
    V(out2) <+ transition(out2var,0,1e-12);
     end
endmodule
 Best regards,
Kenneth
  • RobinCommander
    RobinCommander over 12 years ago
    Thanks for the suggestions guys. Using almSetStringParameterList fixed the netlisting problem.
    Another nice to have would be the ability to read a complete line so I could ignore comment lines, but I can't see a way to do this. $fgets() would do this if supported.
    Robin
    Hi Robin,
    I also filed CCR 1230574 asking for $fgets support in spectre's implementation of Verilog-A. I did try a workaround using %[^\n] but that's not legal in Verilog-AMS (it's how you might do it in C though), so that didn't work either.
