  3. Verilog-A read file separated by delays
  • Replies 12
  • Views 26202
kennethbrun
kennethbrun over 14 years ago
I want to create a Verilog-A module (intended for Spectre simulations) that will read a stimuli file on some predefined format and apply the stimulis to the outputs.
The input stimuli file format could be like this:
OUT1=1
OUT2=0
# = 25
OUT1=0
OUT2=0
In the above file, the intention is to initially set OUT1/2 to some well-defined value and then change them 25 time units (ps in this case) later. I create the file myself (in another tool) and the format is not fixed in any sense, but the basic concept is, that it should include both timing and signal/value information.
 I've been trying to create this Verilog-A module, but I got stuck while trying to create the time delay. Below is my Verilog-A code so far. After some initial setup, the idea is that I run a check at each time unit step (~1ps). If a delay counter is higher than 0, then I count it down, if not: then I read the file (and potentially changes the delay counter when "#=250" is read).
When simulated 500ps in Spectre,  the last to output assignments are never effectuated. According to my debugging, it seems that the file pointer has reached EOF when exiting the inner loop. But I do not understand this, and I cannot see any alternative implementation to avoid this problem - any suggestions for a way through this?
 module vloga_component(vdd1v2,out1, out2);
   output out1;
   electrical out1;
   output out2;
   electrical out2;
   input  vdd1v2;
   electrical vdd1v2;
   parameter string fileString = "/tmp/default" ;
   integer   fd;
   integer   testint1,testint2;
   integer   out1var,out2var;
   string signalName;
   integer   signalVal;
   integer   delayCounter;
   analog
     begin
    // THIS BLOCK IS FOR FILE READING:
    @(initial_step)
      begin
         delayCounter = 0;
         fd = $fopen(fileString, "r");
      end // @ (initial_step)
    @(timer(0,1e-12))
      begin
         if(delayCounter>0)
           begin
          // PART OF LOOP WHERE THE DELAY IS IMPLEMENTED
          delayCounter = delayCounter-1;
          $display("Remaining delay: %d ps", delayCounter);
           end
         else
           begin
          // PART OF LOOP WHERE THE FILE IS READ
          while (delayCounter==0 && (!$feof(fd)))
            begin
                    testint1 = $fscanf(fd, "%s=%d", signalName, signalVal);
               case(signalName)
             begin
                $display("WE GOT A MATCH: %s = %d ; TEST2=%d",signalName,signalVal,testint1);
                $display("Delay: %d ps", signalVal);
                delayCounter=signalVal;
             end
             "OUT1" :
               begin
                  out1var = signalVal;
               end
             "OUT2" :
               begin
                  out2var = signalVal;
               end
             default $strobe("Error. Too weird: %s", signalName);
               endcase // case(signalName)
            end
           end // else: !if(delayCounter>0)
      end
    V(out1) <+ transition(out1var,0,1e-12);
    V(out2) <+ transition(out2var,0,1e-12);
     end
endmodule
 Best regards,
Kenneth
  • kennethbrun
     Anyone with experience in reading stimuli files through Verilog-A at all?
    More general the question can be stated as:
    How can I make a delay (in a transient simulation) dependent on the content of a read file?
    I'd like to investigate, but the day job has been getting in the way... maybe somebody else has the time.
  • RobinCommander
    RobinCommander over 12 years ago
    I take it this isn't possible?
    I started on something similar, but it sounds like it isn't going to work.
  • kennethn
    kennethn over 12 years ago
    Hi Robin,
    I succeeded with the task the last time. I'm currently busy, but will post you ideas within a couple of days. Don't remember the details, but I can look them up...
    /Kenneth
  • RobinCommander
     OK thanks.
    I was also trying to make the file name a parameter but couldn't get it to run in Spectre when I included the path.
    In VerilogA:    parameter string read_file="/path/SPI_commands.txt";
    In spectre.out:      Error found by spectre during circuit read-in.
        ERROR (SFE-874): "input.scs" 12: Unexpected operator "/".
    Line 12 of input.scs:      I0 (net3 net4 net1 net5) SPI_stim read_file=/path/SPI_commands.txt
    If I could persuade the netlister to put quotes around the string maybe this would work, but I haven't found a way to do this.
    Robin
  • kennethn
      Did you try escaping either quotes or slashes?
     E.g.
    parameter string read_file="\/path\/file.txt"
    or
    parameter string read_file="\"/path/file.txt\""
    I do it by:
    parameter string simId = "default";
    and then open the file with:
        fd = $fopen({{"$PROJECTSDIR/",simId}, ".txt"}, "r");
     /Kenneth
  • RobinCommander
     Escaping the quotes or slashes didn't help, I also tried "\042/path\/file.txt\042" (042 is octal ").
    But this feature was just plus, maybe something like your method will work.
    Robin
    Robin,
    There's a bug in correctly setting the view-specific CDF for string parameters in VerilogA views, it seems.
    To solve this, if you do:
    almGetParameterList("mylib" "mycell" ?view "veriloga")
    to find out what parameters you have - in your case you have one called read_file (maybe others too). Set the parameterList to not include read_file, but include all the other parameters (I called them param1 param2) - if there are no others, you can just pass nil instead of '(param1 param2):
    almSetParameterList("mylib" "mycell" '(param1 param2) ?view "veriloga")
    Then tell it that read_file is a string parameter:
    almSetStringParameterList("mylib" "mycell" '(read_file) ?view "veriloga")
    Having done this, it should netlist it with quotes around the fileName.
    I am filing a CCR on your behalf to correct the VerilogA parser/CDF creation to do this automatically.
    As for implementing the delay in the original question, I would do it not by setting a timer every 1ps - because that will hurt simulation performance - but instead keep track of the time of the next "event" and set a non-periodic timer to start then and read the next data from the file).
    Robin,
    Turns out that you don't need to do the almSetParameterList removing the read_file parameter; all you have to do is call almSetStringParameterList().
    I filed CCR  1230515 to get the VerilogA parsing fixed.
  • kennethn
    Robin,
    Here is the important part of my solution to the problem.
       analog
         begin
            @(initial_step)
              begin
                 timeOfNextStep = 0;
                 simTimeStep=0;
              end
            @(cross($abstime-timeOfNextStep*1e-9,1) or initial_step)
              begin
                 fileTimeStep=0;
                 fd = $fopen({{"/path/inputcounter/",simId}, ".txt"}, "r");
                 while($fscanf(fd, "%s = %s", signalName, signalVal)>0)
                   begin
                      if(fileTimeStep==simTimeStep)
                        begin
                           case(signalName)
                             begin
                                timeOfNextStep=timeOfNextStep+signalVal.atoi();
                                $display("INFO: (%m) (time:%g) Delay read from file %s ns",$abstime,signalVal);
                             end
                             "CdrLocked":
                               begin
                                  case(signalVal)
                                    "0": CdrLockedVar = 0;
                                    "1": CdrLockedVar = 1.2;
                                    "X": CdrLockedVar = 0.6;
                                    "Z": CdrLockedVar = 0.6;
                                    "z": CdrLockedVar = 0.6;
                                    "x": CdrLockedVar = 0.6;
                                    default: $strobe("ERROR: (%m) (time:%g) Unsupported signal value for signal CdrLocked: %s",$abstime,signalVal);
                                  endcase
                                  $display("INFO: (%m) (time:%g) Stimuli read: CdrLocked = %s",$abstime,signalVal);
                               end
                               end
                             default $strobe("ERROR: (%m) (time:%g) Unknown signal name: %s",$abstime, signalName);
                        end // if (fileTimeStep==simTimeStep)
                      if(signalName=="#")
                        begin
                           // keep track of the number of "timesteps" in file
                           fileTimeStep=fileTimeStep+1;
                        end
                   end
                 simTimeStep=simTimeStep+1;
                 $fclose(fd);
              end
            V(CdrLocked) <+ transition(CdrLockedVar,0,1e-12);
    end
    The example is not self-contained, but let me know if you need further details.
    /Kenneth
    PS: the performance of this forum is horrible today. Just had three timeouts :(
