  3. How can i know the model which the simulator is using?
  • Views 17601
Muffassir
Muffassir over 14 years ago
 Hi all,
I am using Cadence 6.1.4 and virtuoso ,gpdk180 and ADE L.
I want to know which model (BSIM3.3, BSIM4.6, BSIM SOI 4.0 or EKV 2.6)  of transistor (MOS) is being used by the simulator .how can i do that . Further how can i change the model to EKV 2.6 if possible. what are the steps to be followed.
Thanks in advance..
  • kennethbrun
    kennethbrun over 14 years ago
     I am not familiar with gpdk180 (foundry?), but independent on PDK you should be able to see the transistor models by browsing the netlist.
    Find the include-line pointing to the model file, open the file and compare the content with the transistor instantiations elsewhere in the netlist.
  • berndf
    berndf over 14 years ago
     Check the model libraies in the model directory of your PDK and look
    for the model card
    model ModelName ModelIdentifier
    e.g.
    model nch bsim3v3
     spectre -h in the command line my help to
    Bernd
    In OCEAN you can extract this after a dc operating point having been run (with spectre as the simulator):
    openResults("/path/to/psf")
    selectResult('dcOpInfo)
    outputs() => will list all the devices in the operating point data
    dataType("/I7/M2") => "bsim3v3" (for example)
    I don't think there's an interactive way to get this - but then it's a fairly unusual thing to do.
    The gpdk180 transistor models are bsim3v3. You can see this (as was suggested by kennethbrun) by looking in the model files, which are at <GPDK180instDir>/models/spectre/*mos*.scs .
    Changing them to EKV will involve you having to provide a different set of model files (you'd have to create these yourself) and reference the models in Setup->Model Libraries in ADE. Given that model files are "characterized" (although in GPDK it's an artificial process, so they're effectively made up), that's not a trivial task unless you have some EKV models from elsewhere.
