  3. Bindkeys in IC 6.1.5
  • Subscribers 133
  • Views 14839
AlexGolberg
AlexGolberg over 14 years ago
I created a list of bindkeys for viewing metalls. For example,
list("<Key>1"    "_pteHiLayerSetActiveLpp(dwindow('pteLayerPalette1) \"V1 drawing\") _pteHiLayerSetActiveLpp(dwindow('pteLayerPalette1) \"M1 drawing\") hiRedraw()");  M1/V1
Everything works fine if i work with one cell only (only one layout window is open),but if i use Descend Edit and/or open many windows bindkeys often stop working. The only thing i can do in this case is to exit virtuoso and open in again. Is there a better solution?
    Alex,
    Rather than using the functions that you see in the CIW, better to use the API functions for this. The problem is that you have a dependency on the palette being called pteLayerPalette1, and that will depend on the window you're on. So instead use this as the bindkey definition:
    "leSetEntryLayer('(\"V1\" \"drawing\")) leSetEntryLayer('(\"M1\" \"drawing\"))"
  • AlexGolberg
    Thank you very much, Andrew.
