  3. installscape can't find the right directory
  • Subscribers 133
  • Views 3705
FedericoPI
FedericoPI over 14 years ago
Hi all, i need to configure again my installed release of INCISIVE 9.2.
 But Installscape cannot resolve in the right way the directory I installed the release into. Iscape tells me that I have installed the release in a subdirectory of the IC directory, but the software is installed in a different path. How to choose this path and prevent Installscape using the default?
 Notice that i can still fix it by making again the install release in the same directory but it is a bit boring.
    If you're using the "Classic View" of InstallScape, you can go onto the "View installed releases" tab, and in the bottom right corner there is an "Add Existing Release" button. If you do that, you can give the path to an installation. Having done that, it will appear in the choices on the "Configure Releases" tab.
    Alternatively, if you go onto Preferences->Installscape, you can pick "Original GUI" on the Interface tab, and then when you re-start installscape, the configure choice will allow you to type in a path to the installation you wish to configure.
    Best Regards,
