  3. imax and imelt error in Spectre.
  • Subscribers 133
  • Views 18238
SGGS
SGGS over 14 years ago
While simulating (trans analysis) the circuit of ADC I am  getting the warningat 20ps that
The bulk source junction current exceeds 'imelt'.
The bulk source junction current exceeds 'imax'
 Then at 727ps i am getting the notice that the
The bulk source junction leaves linearized region
The bulk source junction current no longer exceeds 'imax' and imelt..
What these warnings and notices means ...What parameters i should change to avoid these.
I am getting these on only 2 MOSes.
    It is telling you that the current was so large that the device behaviour is not modelled properly. This can arise as a result of discontinuties in the models (maybe of other devices) or sometimes because of something which is causing the devices to move out of their correct operating region. Sometimes having excessively large component values (e.g. 1 Henry inductors or 1 Farad capacitors) can cause instability and excessive signal levels.
    Sometimes it's a reflection of problems with the device models, and having insufficient parasitic capacitance to smooth out the discontinuities. Sometimes it's because you've forgotten to connect up the supplies or signals properly though...
    There are many reasons. Reading a book such as the Designer's Guide to SPICE and Spectre by Ken Kundert can help, or you might want to get in contact with Cadence Customer support for some more specific advice.
