  3. Clicking the AWE plot curve does not choose it?
  • Subscribers 133
  • Views 14893
SUEE
SUEE over 14 years ago
I do not know why but yesterday I met some weird problem.
One of them is: I used the AWE to plot the simulation results and usually/always I could just click the curve I am interested to choose it. The choosen curve will be highlighted in the "Curves" window and I can then change the curve color or line style then.
But yesterday when I click the curve the "Curves" window did not pop out and even I open the "Curves" window manually the curve chosen is not highlighted !?  It makes me diffcult to know which curves I choose (among many curves in one plot) and impossible to change the curve property.
Why?  What can I do?
Thanks a lot !!
  • SUEE
    Sorry again that I forget to mention the version I am using: IC 5.1.0 03/36/2008
    I assume you mean "AWD" (the old waveform tool in IC5141). Anyway, I'm not familiar with the problem you're describing, but it might be worth trying a newer hotfix than the almost 4 year old one you're using there...
