  3. Mouse zoom in IC6.14
  • Views 19876
Kabal
Kabal over 14 years ago
 By default, when i scroll mouse wheel up and down, i get a view in schematic and layout going up and down.
 However, instead of that i want it to do zoom in and out.For example on mouse wheel Up scroll, i want zoom IN, on mouse wheel down scroll i want zoom OUT.
where can i change those settings?
  • venuuuuu
    venuuuuu over 14 years ago
     hi,
        Can you enter following code  in CIW
                   hiSetBindKey( "Schematics"    "None<Btn4Down>"     "hiZoomInAtMouse()")
                    hiSetBindKey( "Schematics"    "None<Btn5Down>"     "hiZoomOutAtMouse()")
                    hiSetBindKey( "Layout"    "None<Btn4Down>"     "hiZoomInAtMouse()")
                    hiSetBindKey( "Layout"    "None<Btn5Down>"     "hiZoomOutAtMouse()")
  • Kabal
     yes it worked. thank you.
    then i just put those in .cdsinit to make it permanent.
     and i guess it worked, because it was still on after program restart.
  • Moof
    Moof over 12 years ago
       Is there any way to set the amount of zoom per step?  The documentation only says it is a zoom factor of 2, which is rather coarse.
    Thank you.
    You could change the Btn4Down and Btn5Down bindkeys to use hiZoomWindowAtMouse(hiGetCurrentWindow() 1.6) and hiZoomWindowAtMouse(hiGetCurrentWindow() 0.625) or whatever factors you want (the default is 2 and 0.5). The hiZoomInAtMouse and hiZoomOutAtMouse are just simple wrappers around this function with factors of 2 and 0.5
