  3. Turbo Toolbox Error
  • Views 16191
Turbo Toolbox Error
mjgoh
mjgoh over 14 years ago
Hi, I have problem to use turbo toolbox for Virtuoso Layout Editor IC6.1.4. I use Techfile validator to check my tech.db, and below is the message i get. _leTbEnvValidator(cv) ------- TURBO TOOLBOX TECHFILE VALIDATOR ------- Copyright 2006 - Cadence Design Systems, Inc. ------------------------------------------------ *WARNING* (TECH-290096): techGetOrderedSpacingRule: Layer-purpose pair nil was not defined. Verifying techfile: tech.db Verifying layer map in tech params... Some layers are missing from the techfile or are invalid. These layers must be added before the presence of physical rules can be established. ------------------------------------------------ Techfile test complete. Status: FAILED For details see ~/testtech_tech.db.dat nil The message show some layers missing, how can i know which layers are missing in my techfile? When i go to Options->Toolbox Options, then click on Setup Utility, below error message show in CIW. "*Error* hiiDeleteForm: hiiListToFieldUT: invalid hiField - floatStruct@0x13aaef48". What's this layer mean? Can any one help? Thanks in advance.
  • Quek
    Quek over 14 years ago
    Hi mjgoh
    I think your problem is related to this post.
    Best regards
    Quek
  • mjgoh
    Hi Quote, I wish to use the rules stretch, in the turbo toolbox the command is _leTbCommand( "_leTbRuleStr()" ). Do you know any other way to use it without turn on turbo toolbox? Thanks. mjgoh
  • Quek
    Hi mjgoh
    You can do it as follows:
    a. Go to "Edit->Quick Align"
    b. Change to partial selection mode
    c. Select the edge to be stretch and click it as reference edge
    d. Press F3 to display options form and set spacing if necessary
    e. Click target edge
    f. The reference edge will be stretch towards the target edge with the specified spacing
    Best regards
    Quek
