  3. mapping logical libraries in AMS Designer (VHDL)
  • Replies 7
  • Subscribers 133
  • Views 19429
FedericoPI
FedericoPI over 14 years ago
 Hi all,
 I am using a vhdl description where i put the directive:
library pippo;
use pippo.VTABLES.all;
pippo is defined in cds.lib, and inside pippo i have imported the package VTABLES with vhdlin.
I tried to simulate with AMS a schematic where is some spectre and the vhdl description with this directory (the VHDL has been succesfully imported). It gives me the error on library directive:
 logical library must be mapped to design library
(or something very close)
i can-t understand why. in my cds.lib the library is referenced. maybe i should compile the package during import, but i don-t know how to set the correct work library. Can you help me with the right procedure?
 Note that i have succesfully simulated in AMS other vhdl blocks, i use OSS netlister, and cells in pippo library that don-t gives library pippo; as a directive correctly work.
    For completeness, which subversion of the IC tools are you using (Help->About in the CIW), and which version of the simulator are you using (irun -version from the UNIX prompt)?
  • FedericoPI
    The versions are: IC 6.1.4-64b.500.9 irun 9.20-s022
  • FedericoPI
     Up!!!
    What does that append mean?
  • FedericoPI
    that I am still in trouble and i re upped the post, some days after the moment i added the version of the software.
    OK, I have no Ideal what "re upped the post" means, but if you have an urgent problem, you should contact Customer Support. The community forums are a community assisted mechanism - you are relying on people to volunteer their time to answer (that includes me - responding here is not part of my role at Cadence - I do it in my spare time). In order to investigate your problem I'd have to gather together some data and do some tests, and personally I have not had the time to do that due to work commitments. Others may have the time, of course, and I may do in due course, but anything urgent should really use the proper support channels.
  • FedericoPI
    Solved. The path to the precompiled library has to put into the -reflib argument of irun. It can be set into the Miscellaneous tab into the AMS Simulator Option.
