  3. how to simulate device noise when the circuit has chopping...
  • Views 16720
how to simulate device noise when the circuit has chopping block
kunmingcai
kunmingcai over 14 years ago
Dear All:
I want to get the noise performance of a block. the block including an opam and a common mode regulator which is chopping operation(the only clock in this block).
How can i run simulation to get the device noise.
it seems that pss+pnoise can do this. but my simulation do not comply with chip test result.
maybe there is some setting issue when run the simulation. could anyone tell me how to set up the simulation?
now i am setting the beat frequency the chopping frequency,what about the harmonic number?
 do i need to care about some other settings?
Thanks for any share.
  • Quek
    Quek over 14 years ago
    Hi Kunming
    Would you please let us know the specific version of spectre which you are using?
    Terminal>spectre -W
    (Output should be similar to "11.1.0.281.isr4")
    It might be good to retry using latest version of spectre in case you are experiencing a bug which affects the pss+noise results.
    Best regards
    Quek
  • kunmingcai
    Hi, Quek:
    Thanks for your reply.
    my version is:
    /tools/cadence>spectre -W
    sub-version  10.1.1.128.isr9
    Best Regards!
    Kunming
    A good place to start would be to read Simulating switched-capacitor filters with SpectreRF . There is also a new option in MMSIM11.1 called "full spectrum" on the pnoise form which makes it much easier to ensure you have sufficient sidebands.
    Once you've reviewed the above, if you're still not getting meaningful results, you should contact Cadence Customer Support.
