  3. Difference between n/p –select and n/p - active layers in...
  • Subscribers 132
  • Views 3518
Difference between n/p –select and n/p - active layers in CMOS layout techniques.
RAO VINAY
RAO VINAY over 14 years ago
What is the significance of using n/p select layers along with n/p active layers to make a CMOS active device? Why we need to draw extra n/p select layers though we can distinguish P and N regions just by using P/N active regions?
Vinay Rao.
    Vinay,
    Your question is almost certainly specific to the particular foundry/process design kit you're using, rather than being general to all CMOS technologies. I don't know what you mean by "n/p select layers" so can only assume that it's something in the particular technology you're using. In most technologies you either draw a diffusion (or "active") region and then draw an implant layer to make it N or P (or you draw N-diffusion or P-diffusion).
