  3. Drawing with Viva
  • Subscribers 133
  • Views 16637
Drawing with Viva
BradW
BradW over 14 years ago
I was wondering if there was any code/interface to allow custom lines to be drawn on a waveform in Viva. My immediate need is to add an "eye" to an eye diagram plotted using the calculator. In the past I've used markers to find the points and then just added the lines in powerpoint. I'd like to be able to automate the actual drawing of the eye to show the waveforms pass spec. For reference I'm using 6.1.5. Thanks
    Something like this will do it:
    line=abMakeWaveform(list(0.5 0.75 0.75 0.5 0.25 0.25 0.5) list(0 20n 60n 80n 60n 20n 0))
    drGetWaveformYVec(line)->units="V"
    ; this one not too critical
    drGetWaveformXVec(line)->name="time"
    drGetWaveformXVec(line)->units="s"
    Using this code:
    /* abMakeWaveform.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 14, 1999
    Modified   Dec 10, 2007
    By         A.D.Beckett
    A simple function to throw together waveforms for
    test purposes. Usage:
    abMakeWaveform('cos linRg(1 100 1)) => o_waveObj
    Returns a waveform with x axis 1 to 100, in 1 steps, with y
    axis the value of the x.
    A more complex example:
    abMakeWaveform(lambda((x) x*sin(x)) linRg(-40 40 0.1))
    Can be plotted in OCEAN using plot(var).
    Also supports the first argument being a list of y values:
    abMakeWaveform('(5 6 7) '(1 2 3))
    Note the lists must be equal length.
    An optional third argument which is the data type may be supplied,
    e.g. 'double (default) 'single etc. Finally a fourth argument
    may be given if the x-axis wants to be a different type. For example
    for bar graphs:
    abMakeWaveform('(1 -2 4) '("NOM" "SLOW" "FAST") 'double 'string)
    SCCS Info: @(#) abMakeWaveform.il 12/10/07.13:48:06 1.4
    * The generic function takes a function object, or the name of *
    *      a function (a symbol) and calls that function for       *
    *   each of the x values. This would be nice if it could be    *
    *    done as a method, but the problem is that you can only    *
    *   have a method specialised on user defined functions, not   *
    *                      binary functions.                       *
    (defgeneric abMakeWaveform (func xvalues @optional (yDataType 'double)
        xDataType)
      (let (xVec yVec wave)
           (setq wave (drCreateEmptyWaveform))
           (unless xDataType (setq xDataType yDataType))
           (setq xVec (drCreateVec xDataType xvalues))
           (setq yVec (drCreateVec yDataType (mapcar func xvalues)))
           (drPutWaveformXVec wave xVec)
           (drPutWaveformYVec wave yVec)
           wave
    * A method is defined to allow the first argument to be a list, *
    *               and do something different there.               *
    (defmethod abMakeWaveform ((yvalues list) xvalues @optional
        (yDataType 'double) xDataType)
           (when
            (and (listp xvalues) (equal (length xvalues) (length yvalues)))
            (setq yVec (drCreateVec yDataType yvalues))
            wave
