  3. Parallel Monte Carlo runs using AMS?
  • Subscribers 133
  • Views 15311
aakhavan
aakhavan over 14 years ago
Using IC615, if I run an APS monte carlo sim, I can set it to 2 jobs, and I'll get 2 spectre threads, thereby running two monte carlo iterations simultaneously. If I do this with AMS, however, it will still only run one iteration at a time. Am I missing something here or is it just simply not supported?
    I just tried this in 6.1.5.500.9 and I get two jobs running (e.g. 1-25 and 26-50) simultaneously.
    I don't see any report of this as a problem even in earlier subversions. So you might want to contact Customer Support to see if we can identify what is causing your problem.
