  3. mmsim61
  • Subscribers 133
  • Views 14429
mmsim61
wighou
wighou over 14 years ago
 I am actually working with MMSIM72. But, I need to verify and old simulation that I simulated with MMSIM61, that is different from the result obtained with MMSIM72. But I lost MMSIM61 and it is not more available on the cadence download platform ? Does it exist a way to download it ?
Regards
    You would need to contact Cadence - it might be possible to get this for you (although in general there is no commitment to supply old versions).
    You might also want to check the latest version (even MMSIM72 is no longer supported - the last hotfix was from 9 months ago). The latest version is MMSIM11.1 . Just in case it's a problem with the specific version you're using...
