  3. Nodeset for subcircuit
  • Views 17926
titanic
titanic over 14 years ago
For cadence analog design envirenment i built 32x32 memory array. I want to nodeset the sram latch.
If i use simulation -> convergence aids -> nodeset , i am gonna have to nodeset every instance of the 6T memory cell.
How can i nodeset subcircuit so that , every instance obeys that nodeset arrangement ..?
(i.e. making nodeset as a property of 6T sram subcircuit for simulation by default)
thanx in advance
  • Quek
    Quek over 14 years ago
    Hi titanic
    You can try the following:
    a. Create a file named "nodeset.sp" with the following lines:
    simulator lang=spice
    .nodeset v(net123)=456 subckt=latch
    where "net123" is a net inside the latch subckt and "456" is the desired voltage.
    b. Add the file as one of the model files in "Setup->Model Libraries"
    Best regards
    Quek
    You can also use wildcards in the nodeset statement (in spectre syntax).
