  3. question about cadence virtuoso
  • Subscribers 133
  • Views 15984
titanic
titanic over 14 years ago
 hi,
I used to use another EDA tool for layout. I could define multi finger mos transistor with different widths, assign # of metal contacts customary and even orientation of the metal contacts.
Now i use cadence virtuoso and i see very limited options on create instance mos( I use UMC 90 kit).... which limits layout optimisation.
Is there some adjustments required..?
thanx in advance
    This is not a limitation of the tool, but almost certainly a limitation of what the design kit has chosen to implement. The best thing would be to contact whoever provided the design kit.
    Best Regards,
  • titanic
     Is there a way to check whether a kit is installed properly or not. ?
    That is going to be specific to the "kit". There is no one way that design kits have to be organised or released - so you'd also have to ask the design kit provider if there is something that can be checked.
