  3. Upper limit of plotting
  • Subscribers 133
  • Views 15046
bobbygang
bobbygang over 14 years ago
Hi Andrew, I ran an ocean and 405 curves should be plotted on a graph. But finally I only got 144 curves. So I guess there is upper limit of curves for one plotting, isn't it? If I‘m wrong what is the possible reason? Looking forward to your reply! Best Regards, Andy Zhu
    Andy,
    Which version are you using and which waveform tool (if IC5141)?
  • bobbygang
    Dear Andrew,
    Thank you for your reply!!
    I use IC6.1.4.
    Best Regards,
    Andy Zhu
    Andy,
    I just used  IC6.1.4.500.13 and was able to plot 500 traces. I don't believe there should be an upper limit (other than memory, in which case you could run in 64 bit mode).
