  3. Initial Condition Sweep
  • Subscribers 132
  • Views 14918
ddr71m
ddr71m over 14 years ago
 I want to  sweep initial condition(node voltages.....) and do a transient analysis....will the sweep analysis give correct results as initial conditions are set once.... or will the initial conditions be changed depending upon swept parameter
    As outlined in the Forum Guidelines, please do not post new questions to old threads - it makes it much harder for anyone reading through existing posts.
    The answer to your question depends a lot on how you are doing this sweep. Please explain how you are doing the "sweep analysis".
