  3. "capgen" error in Assura QRC (RCX)
  • Replies 24
  • Subscribers 133
  • Views 11407
bjbit
bjbit over 13 years ago
Hi all,
I work with the technology of IBM CMOS7RF on Cadence 5.1 (IC5141). Currently I am trying to extract parameters for a self-customized inductor.  By setting "ind" model in schemetic as a blackbox and ignoring mismatches, I go through LVS. Now an error happens in QRC as below.
*WARNING* at "capgen": x-tile size is not floating point number
*ERROR* at "capgen": capgen job quit due to process file errors.
quitting.
 -blocking coupled5_shield1:0.02,M1,M2,M3,M4,M5 -blocking coupled5_shield2:0.02,M2,M3,M4,M5 -blocking coupled5_shield3:0.02,M3,M4,M5 -blocking coupled5_shield4:0.02,M4,M5 -blocking coupled4_shield1:0.02,M1,M2,M3,M4 -blocking coupled4_shield2:0.02,M2,M3,M4 -blocking coupled4_shield3:0.02,M3,M4 -blocking coupled3_shield1:0.02,M1,M2,M3 -blocking coupled3_shield2:0.02,M2,M3 -blocking coupled2_shield1:0.02,M1,M2 -blocking singleEndA_shieldT:0.02,MT,ML -blocking singleEndA_shield5:0.02,M5,MT,ML -blocking singleEndA_shield4:0.02,M4,M5,MT,ML -blocking singleEndA_shield3:0.02,M3,M4,M5,MT,ML -blocking singleEndA_shield2:0.02,M2,M3,M4,M5,MT,ML -blocking singleEndA_shield1:0.02,M1,M2,M3,M4,M5,MT,ML -res_blocking singleEndA_shieldT:0.02,ml -res_blocking singleEndA_shield5:0.02,ml -res_blocking singleEndA_shield4:0.02,ml -res_blocking singleEndA_shield3:0.02,ml -res_blocking singleEndA_shield2:0.02,ml -res_blocking singleEndA_shield1:0.02,ml -blocking singleEndT_shield1:0.02,M1,M2,M3,M4,M5,MT -blocking singleEndT_shield2:0.02,M2,M3,M4,M5,MT -blocking singleEndT_shield3:0.02,M3,M4,M5,MT -blocking singleEndT_shield4:0.02,M4,M5,MT -blocking singleEndT_shield5:0.02,M5,MT -blocking singleEnd5_shield1:0.02,M1,M2,M3,M4,M5 -blocking singleEnd5_shield2:0.02,M2,M3,M4,M5 -blocking singleEnd5_shield3:0.02,M3,M4,M5 -blocking singleEnd5_shield4:0.02,M4,M5 -blocking singleEnd4_shield1:0.02,M1,M2,M3,M4 -blocking singleEnd4_shield2:0.02,M2,M3,M4 -blocking singleEnd4_shield3:0.02,M3,M4 -blocking singleEnd3_shield1:0.02,M1,M2,M3 -blocking singleEnd3_shield2:0.02,M2,M3 -blocking singleEnd2_shield1:0.02,M1,M2 -blocking ml_transmission,sti,ML -blocking symind3_mlml_m1,sti,M1,MT,ML -blocking symind2_mlml_m1,sti,M1,MT,ML -blocking ind2_mtml_m1,sti,M1,MT,ML -res_blocking symind3_mlml_m1,mt_resistive,ml -res_blocking symind2_mlml_m1,mt_resistive,ml -res_blocking ind2_mtml_m1,mt_resistive,ml -blocking symind3_mlml_bb,sti,MT,ML -blocking symind2_mlml_bb,sti,MT,ML -blocking ind2_mtml_bb,sti,MT,ML -res_blocking symind3_mlml_bb,mt_resistive,ml -res_blocking symind2_mlml_bb,mt_resistive,ml -res_blocking ind2_mtml_bb,mt_resistive,ml -blocking bondPad_PC:5.28,sti,PC,ML -res_blocking bondPad_PC:5.28,ml -blocking bondPad_BB:5.28,sti,ML -res_blocking bondPad_BB,ml /home/zheng072/zy_senser/inductor_test1
*WARNING* Bad return status from RCX script generator. 0x100
I cannot figure out what's wrong with "process file". I have installed Assura QRC package exactly as the document states. Any advices are appreciated.
Thanks.
  • Quek
    Quek over 13 years ago
    Hi bjbit
    Would you please provide the specific version of QRC which you are using? This might be an old bug which has already been fixed.
    Best regards
    Quek
  • bjbit
    Hi Quek,
    Thanks for the quick response.  Here is what I found from the document.
    PDK version: V1.9.0.0
    Assura version: 4.1USR2_HF3
    QRC version: 10.1.2-s078
    bjbit
  • Quek
    Hi bjbit
    Thanks for the info. I meant the actual QRC version which you are using. You can check it in a terminal window using:
    terminal>qrc -version
    Best regards
    Quek
  • bjbit
    Hi Quek,
    Sorry I cannot find this "qrc" command in any directory from linux console. There is no "bin" folder in the installed PDK. I am confused. Could you please help out? Thanks.
    bjbit
  • Quek
    Hi bjbit
    "qrc" is the executable file for running the extraction. If it is not present in your path, it most probably means that you are not using QRC. You might have used the old Assura RCX for the extraction. Please request your IT to download and install PVE package and it should resolve the problem.
    Please note that Assura and QRC comes in separate packages. Assura comes from "Assura" package. QRC comes from "PVE" package.
    Best regards
    Quek
  • bjbit
    Hi Quek,
    Thanks a lot for the info. It seems you are right, since I used "run RCX" under "Assura" manu in Cadence virtuoso. By checking the assura installed in the server, I found the version is  4.1_USR1_HF11, while the version tested in document is 4.1_USR2_HF3. Is RCX default integrated with assura, and QRC is seperated tool? Does the assura version matter for installing and using QRC? So I need to install QRC tool for the availability of the QRC package in my PDK, right?
    Sincerely,
    bjbit
  • Quek
    Hi bjbit
    Yes, RCX is integrated with Assura. QRC is a separate tool. You will need to use the latest version of Assura (41USR2_HF12) together with QRC. Please install PVE and add the following to your .cshrc file:
    setenv QRC_HOME /your-path/PVE11
    set qrcPath=($QRC_HOME/bin $path)
    Yes, you need to install QRC for your PDK.
    Best regards
    Quek
  • bjbit
    Hi Quek,
    I appreciate all of your helps. Thanks a ton.
    bjbit
  • Quek
    Hi bjbit
    You are welcome
    Best regards
    Quek
  • bjbit
    Hi Quek,
    Finally I asked my server manager to get PVE11 package installed. Now my working environment is Assura41 _USR2_HF10 under IC614. Here is a question regarding to setup QRC. When I type "qrc -version" to check version (actually also other commands), no any information poped, even command errors. When I open a layout view and click the QRC menu, "Loading QRC menu..." is shown under it, and a warning of "RCX UI is already loaded" is given in CIW. I guess it maybe a conflict issue between QRC and the integrated old RCX? Any advices to solve it? Thanks in advance.
    Sincerely,
    bjbit
