  3. Cadence 6 Key Lock
  • Subscribers 133
  • Views 14828
Cadence 6 Key Lock
GTStan
GTStan over 14 years ago
Hello Gentlemen, My research team and I are encountering an issue in Cadence 6 (IC6.1.4.500.13 (32-bit)) where dialogue boxes will suddenly be unresponsive to key stroke entries.  This seems to happen at random intervals and the only means of fixing this issue has been to do a cold re-boot of Cadence 6.  We have attempted closing and re-opening all dialogue boxes, but the boxes still remain unresponsive to key strokes.  The CIW will however respond to keyboard entries.  Any insight would be appreciated!
  • skillUser
    skillUser over 14 years ago
    I've seen this under various circumstances, for me it only seemed to happen with a certain window manager setup (Gnome or KDE, I can't remember which, but I don't think that I suffered this issue with IC61x on FVWM) but I think that the culprit was an environment variable setting "XMODIFIERS" - try removing this setting (or changing it?) and see if the problem still occurs. If I remember correctly, removing this setting fixed the issue for me.  Not sure if it is important whether VNC was involved or not, I think that the problem occurred if I was sat directly at the terminal too.
    Hope this helps!
    Lawrence.
  • GTStan
     Thanks for the quick response and insight!  Sadly there is no way to immediately verify that the problem is fixed, since it was never immediately apprenent what would trigger the lock.  We have eliminated the settings in the XMODIFIERS env variable, and things are running smoothly so far.  I'm betting this will be our saving grace.
     Thanks.
