  3. Relxpert prebert error
  • Replies 7
  • Views 18248
Amel
Amel over 14 years ago
I am tryning to run Relxpert for the first time in an interactive mode that is invoking Relxpert from ADE, when I go to prebert stage it fails and I get the following error: RelLink: prebert did not complete successfully. can anyone tell me how to overcome this problem.
thanks
  • Ashish Patni
    Ashish Patni over 14 years ago
    Hi Amel,
    Have a look at relxpert.log and/or prebert.log and see what the actual issue is which caused prebert to not complete successfully. Also, do mention the MMSIM version you are using.
    Ashish
  • Amel
    Hi Ashish Patni,
    by looking to prebert and relxpert logfiles, it seems to be related to the parsing of the rawfile as it is here:
    Error(RELXP-198): The RelXpert simulator failed to parse .rawfile1.sp because of the following error:
    ".rawfile1.sp" 206: SPICE `.usim_opt' cards are not
            supported in Spectre language sections. Use `simulator lang = spice' to
            introduce spice language sections.
    does this mean that I must use Spice instead of spectre?
     For the version : I am using MMSIM7.1 .
    thank you for your help.
    Amel.
  • Ashish Patni
    Hi Amel,
    As the error message suggests, .usim_opt is a spice syntax statement. You need to move the .usim_opt statement into spice language section i.e. you can put the following lines in your netlist -
    simulator lang=spice
    .usim_opt ....
    Please note that if  there are other spice language statements then they also needs to be moved to this section.
    With Regards,
    Ashish
  • Amel
    Hi Ashish,
    Thank you for your relpy,  you are right.
    I have added the "simulator lang = spice" statement before the control statements that are written using SPICE language and "simulator lang = spectre" before statements written with spectre languageguided by the general rules given in  Virtuoso RelXpert Reliability Simulator User Guide. but this does not resove the prolem.
    the following is what I have gotten as prebert logfile:
     prebert:
    *  Cadence (R) Virtuoso (R) RelXpert Reliability Simulator
    *  RelXpert version sub-version  7.1.1.187  32bit 08/18/2009 21:18 (usim440-8)
    *  Copyright(C) 2001-2007, Cadence Design Systems, Inc. All rights reserved worldwide.
    *  Cadence and Virtuoso are registered trademarks of Cadence Design Systems, Inc.
    *  All others are the property of their respective holders.
    *  Protected by U.S. Patents:
    *  5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238; 6,088,523;
    *  6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964; 6,349,272; 6,374,390;
    *  6,493,849; 6,504,885; 6,618,837; 6,636,839; 6,778,025; 6,832,358; 6,851,097;
    *  7,035,782; 7,085,700
    *  USER: chenouf HOST: turquoise HOSTID: 84A1A852 PID: 13253
    *  Memory: available: 588.8409 MB physical: 2.1474 GB
    *  CPU(1 of 2): CPU0 sparcv9 1600Mhz
    *  Netlist file: m6File
    *  Starting time: Wed Mar 14 15:34:31 2012
    *  Command Line Input: prebert -sp -p1 m6File m6File.p1
            The Rexlpert simulator failed to parse the netlist.
            Correct the above errors and run the simulation again.
    . Run the SPICE simulator spectre to make sure the netlist file passes before correcting the statement in file  and running the simulation again.
    I  tried to run the netlising It passes successfully but when I run prebert again I get the same error. I am confused since this time in the logfile  I can not see why the simulator  fails to parse rawfile.sp.
    regards
    Amel.
    Amel,
    It's probably wise to contact customer support. There were some changes around that time to move the front end in relXpert to use the newer SFE (Simulator Front End) as opposed to the Ultrasim Front End which was used before. There's an environment variable to tell it to use the old front end, but that's not recommended and really you need to fix the models when using newer versions.
    So please contact customer support.
  • DhawalMahajan
    DhawalMahajan over 9 years ago
    I am trying to run Relxpert and am getting the same error(REL-198). I tried using simulator lang=spice before the beginning of Relxpert syntax but of no avail. Could you please tell me that:
    1. With the use of newer SFE, does the syntax of Relxpert statements which is spice based, changed?
    2. If your answer is yes to above question, then where do I find documentation for the new Relxpert syntax?
    3. Is the current version of Relxpert compatible with the recent version of Spectre(151.15.10.ISR14)?
    Dhawal
    Dhawal,
    Answers (rather belatedly) to your questions:
    1. The change happened in Spectre 7.1.1 - so some time back.
    2. In the Virtuoso® RelXpert Reliability Simulator User Guide. In MMSIM151 (since RelXpert is part of the MMSIM release), you can access this with <MMSIMinstDir>/tools/bin/cdnshelp. It's in Chapter 6 "Setting Up Models for Simulation".
    3. Of course, since RelXpert is shipped as part of the MMSIM installation.
