  3. breaking the loop with diffstbprobe
  • Subscribers 133
  • Views 16899
pirateKing08
pirateKing08 over 14 years ago
Hello, I have a linear regulator with 2 loops, one within the other. For stability analysis if I break a wire with iprobe which breaks all loops I get a certain answer of unity gain freq, phase margin and gain margin. So that works. If i then break the loops at a differential point of the same inner loop such that all loops are broken again but use the diffstbprobe component my equations fail because there is no unity gain crossover point so I suppose the complicated circuit suddely seems first order! Which I think is unlikely. So as an experiment if I break the loop again at the single wire point but put in 2 vcvs components so the single wire break looks differential then use the diffstbprobe component again I get answers for UGF,PM and GM. (Perhaps its wrong to use vcvs for this purpose as it forces the loop gain sense to be voltage instead of voltage and current as middlebroke requires and also the bilateral nature of the break may artificially become unilateral but it still shows the diffstbprob can work). Anybody had success breaking differential loops?
Cadence version is 6.1.5-64b.500.8
Rgds
Lance
    Lance,
    First of all, you're not breaking the loops when using iprobe or diffstbprobe; the loops remain closed.
    I don't know what you mean by "my equations fail" - what equations?
    I've used diffstbprobe without problems - so I think you will probably need to show exactly what you're doing - maybe best handled via customer support so an AE can look at your data/setup?
    Kind Regards,
  • pirateKing08
    Wow thanks for your very speedy reply Andrew.
    Yes I shouldn’t have used the word break.
    I had calculator equations of UGF,PM and GM.
    OK i'll go via customer support
     Rgds
     Lance
