  3. Noise Analysis
  • Subscribers 133
  • Views 15026
Noise Analysis
Jithin
Jithin over 14 years ago
What does CDF parameters
1. noise file name
2. number of noise/frequency pairs in the properties of source indicates and
how does the value for each be given when noise analysis is done.Please quote
with an example if my square wave running at a frequency of 450MHz and having a supply voltage of 3.3V.
Thanks in advance.
with regards,
Jithin K
    Jithin,
    CDF parameters on what? I'm presuming you're talking about one of the independent sources in analogLib? e.g. vsource, isource, vdc, etc? Please clarify.
    Probably you can get the answer to your question by looking in the Analog Library Reference manual in the documentation, or by using "spectre -h vsource" or "spectre -h isource" at the UNIX prompt (or looking in the Spectre Reference manual in the simulator documentation).
    Knowing what you should set them to (if at all) is rather dependent on what you're trying to model.
  • Jithin
    Thank you Andrew and I will look into the doccuments that you sort out.
    with regards,
    Jithin
