  3. Cadence Calculator Function for difference between two ...
  • Subscribers 129
  • Views 24047
Cadence Calculator Function for difference between two voltages
JustinTaylor86
JustinTaylor86 over 13 years ago
 I am running a transient simulation for x seconds
 I would like to find the maximum difference between the applied input voltage and obtained output voltage over the duration of the x second transient simulation.
So far I have VT("/vout")-VT("/vin") obviously.
 Is there a calculator expression for what I want to do?
    You could use the ymax function - so ymax(VT("/vout")-VT("/vin"))
    If you want to do it only for a portion of the simulation, you could use the clip function, and then do ymax:
    ymax(clip(VT("/vout")-VT("/vin") 1u 5u))
    for example.
