  3. Cadence ADE Simulating .spi of Standard Lib using Spect...
  • Replies 9
  • Subscribers 133
  • Views 20909
Cadence ADE Simulating .spi of Standard Lib using Spectre
tstoll
tstoll over 14 years ago
 Hi -
I have a PDK in which I have all standard cells (inverters, nands,etc.) defned in one common .spi file.
I have standardlib symbols and used them within my analogic schematic for simulation.
I defined on the toplevel global vdd!, gnd!, and also used CDF (VDD netSet vdd!, and VSS netSet gnd!) to be sure that the instantiated inverter has its correct supply and ground voltage.
The .spi standard Lib file I included via the Simulation Files Setup menue (Stimulus File).
It is netlisting and simulating.. but the inverter is not inverting.. the output follows exactly the input.
Any hint on that?
I do not know if that has something to do with it, but at the beginning, I see in the simulation log file following message:
" Unable to compile ahdlcmi library, see input.ahdlSimDB..
" Could not open ahdlcmi module library input.ahdlSimDB.."
I appreciate every comment !!
Cheers,
tOM
    Bit hard to tell without seeing it, but are the pins connected in the right order? In other words, check the instantiation in the netlist produced by ADE against the order in the .SPI definition.
    The ahdlcmi messages are unlikely to be anything to do with this.
  • tstoll
     Hi Andrew -
     There are just 2 pins in the .spi file:
      .SUBCKT INV1 Y A
    *|GROUND_NET VSS
    *|NET Y 0.000582552PF
    Cg1 Y VSS 5.82552e-16
    *|NET A 0.000545819PF
    Cg2 A VSS 5.45819e-16
    * Instance Section
    MM2 Y A VSS VSS NCH_TN ad=0.294p as=0.608p l=0.18u pd=2.18u ps=4.53u w=0.6u
    MM1 Y A VDD VDD PCH_TN ad=0.445p as=0.83p l=0.18u pd=2.79u ps=5.59u w=0.9u
    .ENDS
     In the netlist of ADE it looks like:
     I37 (net026 net023) INVX1
    --> if I give it a CDF parameter for VDD and VSS.. where does that info stand in the netlist?
    tOM
    So effectively VDD and VSS are global connections into the subckt in the included file. However, they would not be global in the resulting netlist from ADE. You might need to have an include file with:
    global VDD VSS
    vddcon (VDD vdd!) vsource dc=0
    vsscon (VSS vss!) vsource dc=0
    to ensure everything gets connected together?
  • tstoll
     Hi Andrew - thx a lot for the fast response - even on a Sunday !!
    Would that mean I have to add this file by hand?
    tOM
    Yes, and reference it via Setup->Model Libraries in ADE.
    Alternatively change the included .spi file to substitute VDD to be vdd! etc (ie match the global names used in the netlist produced by ADE)
  • tstoll
     Hi Andrew -
    could that be saved in the .cdsinit somehow?
    Like:
    envSetVal("spectre.outputs" "currents" 'string "all")
     Only drawback I see.. now I cannot give different parts of the digital part different VDDs, or?
     (I am going to try that out now and let you know asap)
    tOM
  • tstoll
     Hi Andrew -
    I created now a file:
     globals.scs
    with following lines:
    global VDD VSS
    I still have a vdd! symbol and a vss! and gnd! definition in the toplevel..
    When trying to simulate I get the fatal error :
    "The following branches from a loop of rigid branches (shorts) when added to the circuit:
      vddcon:p (from 0 to vdd!)!
    Any idea?
    tOM
    You must have another source in parallel somehow. Hard to know since I can't see precisely what you've done.
    Coming back to your earlier point - if the included netlist relies on global connections, you can't make it non-global later. If the supply connections to the standard cells were via pins, you could use the netSet approach so that your symbols still only have the signal pins, but the stopping view has the additional pins with netExpr on them. You'd have to edit the .SPI to have power supply pins on every standard cell, and not make them global.
    You might be better off contacting customer support about this then we can take a look at precisely what you've done without you needing to share potentially confidential information in a public forum.
  • tstoll
    I got it to work!! There have been a parallel source!
    Thanks so much, at least I can simulate now with one global supply voltage! That helps quite alot!
     Best greetings, tOM
